Wiring harness is a mess has anyone ever tore it all out and only put in the basics. Power ,ignition ,starter, stator and regulator
By Mark Anderhalt
By Josh5696
By John Gubancsik
I started my UT400 but forgot to buckel my seat belt. It bogged down and then died. Only way I could restart it was to press the gas pedal and if I let up on it, it stalls. Any suggestions? Thanks.
By didgeridoo
