I am starting to see more and more aftermarket tires on peoples troopers on here and was wondering what you all thought about your choice. I want to put some one mine but I'm not sure if I should go with a all terrain type tread or something more aggressive.
I haven't had mine on long enough to give an honest answer, but I believe they're the best I could get for my rims and was influenced by my son's off road racing knowledge, would have used B. F. Goodrich if they made one for 14". You got to consider your type of riding too. I'm not aggressive in general but occasional, get very aggressive, so I went with what will do the job and last as long as possible, least expensive over long run. I do like the bead/rim guard on these though. Photo later.
kinarfi
What brand and what size are you running?
kinarfi
I'm running Super Swampers and they seem to get the job done in our sandy rocky terrain. I paid $499.90 for 5 tires including shipping from JC Whitney.
In order to run them all around I had to get a couple of rims as the stock rear rims are to wide. Now I have a spare that will fit each corner.
Gumball
What size are they?
Gumball
The Super Swampers are 28x8.50x14LT. They are a little more aggressive than a normal truck tire. You can see the specs on the Super Swamper web site. http://www.intercotire.com/. The picture is the TSL bias.
I don't know where you're located but if there's a Costco nearby they will dismount and remount your tires for $11.00 a tire. That includes balancing and a new valve stem. They definitely need balancing. Each tire took around 3 ounces of weight. If you don't balance them it's hard on the suspension as well as the tire.
Gumball
  • 6 months later...
4x4x454, this is what I like http://www.simextyres.co.nz/simex-article....cle=-2092972571 if only they made one our size. Never the less, something along this paten is the way I want to go for my terrain (mud, rocks and metal roads). Does anybody know of another brand with this type of tread paten?
Cheers Mike.
silverbullet.
Mike we have found Super Swamper27-9.5-14 dot.Or27-10-14 6 ply .Maxxis big horn 6 ply nice ride but great on any terrain. GBC Grim reaper 27-11-14
27-9-14 8 ply. Hope this will help
    • By GunnersTacklebox
    • By Duncan
    • By JSwearer
      Does anyone have any suggestions for aftermarket shocks.  I have a T-Boss 550 and took it riding in some rough trails and the stock suspension was uncomfortably rough.
