What after market tires are you using and how do you like them
I haven't had mine on long enough to give an honest answer, but I believe they're the best I could get for my rims and was influenced by my son's off road racing knowledge, would have used B. F. Goodrich if they made one for 14". You got to consider your type of riding too. I'm not aggressive in general but occasional, get very aggressive, so I went with what will do the job and last as long as possible, least expensive over long run. I do like the bead/rim guard on these though. Photo later.
kinarfi
What brand and what size are you running?
kinarfi
I'm running Super Swampers and they seem to get the job done in our sandy rocky terrain. I paid $499.90 for 5 tires including shipping from JC Whitney.
In order to run them all around I had to get a couple of rims as the stock rear rims are to wide. Now I have a spare that will fit each corner.
Gumball
What size are they?
Gumball
The Super Swampers are 28x8.50x14LT. They are a little more aggressive than a normal truck tire. You can see the specs on the Super Swamper web site. http://www.intercotire.com/. The picture is the TSL bias.
I don't know where you're located but if there's a Costco nearby they will dismount and remount your tires for $11.00 a tire. That includes balancing and a new valve stem. They definitely need balancing. Each tire took around 3 ounces of weight. If you don't balance them it's hard on the suspension as well as the tire.
Gumball
  • 6 months later...
4x4x454, this is what I like http://www.simextyres.co.nz/simex-article....cle=-2092972571 if only they made one our size. Never the less, something along this paten is the way I want to go for my terrain (mud, rocks and metal roads). Does anybody know of another brand with this type of tread paten?
Cheers Mike.
silverbullet.
Mike we have found Super Swamper27-9.5-14 dot.Or27-10-14 6 ply .Maxxis big horn 6 ply nice ride but great on any terrain. GBC Grim reaper 27-11-14
27-9-14 8 ply. Hope this will help
    • By Duncan
      I got a utv from lowes it has one tire in the back that is the same size as the front tires so it has 3, 26-9-14 and 1 26-11-24. i want to change the rear tire to the same one as the other.So instead of buying a new rim will a 26-11-24 tire fit on a 26-9-14 rim.
    • By diamondjfarm
      Thanks.
    • By hdtran
    • By Mike Turner
      American SportWorks LM 650 won’t start at times. Starter won’t engage the solenoid just “clicks” much like a weak battery would cause. Battery was replaced and problem went away and then came back. Replaced positive battery terminal. Problem resolved then returned. Replaced negative battery terminal. Problem gone then returned. Replaced the positive and negative battery cable ends. Problem resolved and now returned. The repair lasts for maybe 12 starts, then the solenoid just “clicks” again as it will with a weak battery. So I replaced the ignition switch. Problem solved for a week. With each “fix” the problem is resolved but only temporarily. Does anyone have any suggestions ? To replace the starter is expensive especially if it’s not the problem.
    • By sxr951
