  • Alex changed the title to Hisun HS500 No power in reverse
Not sure what you mean by “spin”. I’ve not noticed any issues but haven’t specifically tried to see if it would “spin” in reverse.  I heard the HS 500 will automatically lock the differential when needed but haven’t  verified that.
Hi Brent, just what I said, I live up here in the great Northeast ans sometimes when driving in snow you get sorta stuck, if the tires would spin in reverse you can get out, but when it's in reverse in that situation it just bogs, it'll spin the tires going forward not reverse.
  • 1 year later...
    • By Grant
    • By Flanman55
    • By Croppy38
    • By camojay
    • By weasel
