Howdy
2012 rzr800s......customers of mine. I have done everything he needs for years to all his machines... But he thought he was going to save money by using his brother in law instead of me and bought this unit without me being present and his brother in law doesnt know shit, didnt bother to find out what is done to motor, fuel to support turbo,  has no idea if its running on the autotune programmer or the dynojet because apparently previous owner told him it was dyno tuned.....contradicting the autotune....
Is anyone willing to give me an idea of what this thing should have to support the turbo....i have done countless turbo motors just not an 800 and my customer is requesting i get it ready for spring.....im not comfortable letting this thing go at 10psi without knowing what it should have to support 10psi.   Thank you !
Btw its a stage 1 bmp kit.  Did verify injectors are 550cc which seems like alot of injector for a twin......
  • Alex changed the title to 2012 Polaris RZR 800s turbo questions
      Howdy new member here . My hobby's Rabbit dogs , gamefowl . I'm retired from my real job but I stay busy with the hounds and gamefowl . So to help around the farm I ran across an old 2007 CC Big Country 4x2 to haul feed , water , sprayer and my sorry a$$ .It is in pretty good shape , 781 hrs. good plastic , tires, ect. . But as anything outside and 18 years old it needs seats ! The thing I have found wrong mechically the Diff. Lock Acturtor is broken where it mounts to the bracket ( partly why Im here ) . Hoping someone here can help  ! Just my wish list but Id like to find a roll cage and a composit/plastic top for it Im thinking I'll need a donor to salvage these things from ( again partly why Im here ) . If anyone reeds this and has or knows of any of threse parts PLEASE HOLLER !!
      Randy
    • By Troy C
    • By redneckred
      Can anyone tell me how to get the engine codes to display on a 2012 Bennche Bighorn 700X?  I played with the gauges once and lucked up on this but can't remember what I did.  Will the codes automatically display if there is a code or do you have to cycle through the display?
    • By Kingfish
