Howdy
2012 rzr800s......customers of mine. I have done everything he needs for years to all his machines... But he thought he was going to save money by using his brother in law instead of me and bought this unit without me being present and his brother in law doesnt know shit, didnt bother to find out what is done to motor, fuel to support turbo,  has no idea if its running on the autotune programmer or the dynojet because apparently previous owner told him it was dyno tuned.....contradicting the autotune....
Is anyone willing to give me an idea of what this thing should have to support the turbo....i have done countless turbo motors just not an 800 and my customer is requesting i get it ready for spring.....im not comfortable letting this thing go at 10psi without knowing what it should have to support 10psi.   Thank you !
Btw its a stage 1 bmp kit.  Did verify injectors are 550cc which seems like alot of injector for a twin......
  • Alex changed the title to 2012 Polaris RZR 800s turbo questions
    • By redneckred
      Can anyone tell me how to get the engine codes to display on a 2012 Bennche Bighorn 700X?  I played with the gauges once and lucked up on this but can't remember what I did.  Will the codes automatically display if there is a code or do you have to cycle through the display?
    • By Kingfish
    • By Fishing Wiskers
      Top speed is 30mph on flat grass ground.  but it will not go up minor hills forward or reverse without a runing start.  If you start at the bottom of the hill machine will stop about 1/2 way up.  I have the engine cover off and you can see the outside of the drive clutch will stop spining., and the engine does bogg down some.  Dosent matter if engine is cold or warmed up.  Seat belts are connected.  Fuel is clean
      I am not sure how to check for codes with this machine,  can anyone teall me how to do it?
      Compression with hot eng is 145,  valves adjusted to .005 with a cold engine.  Dash shows 426 hours
    • By Chas
      When traveling in the 40 mph range and throttle is released machine starts surging instead of a gradual slow down any help would be appreciated as dealer is clueless
    • By Paul Angstadt
      Paul
