Good afternoon.
I have a 2010 hisun HS500utv. The vehicle had an oil leak in the rear drive shaft in the connection to the engine.
After disassembly the problem was not the retainer but a small star-shaped seal that was tightned with a nut between the washer and the flange.
I don't know if the seal is part of the washer (if it's glued) because I can't find the reference for this seal in any catalogue.
If anyone can help me I'll be forever grateful.
Attached photos.
Best Regards,
João Ferreira.
  • Alex changed the title to Hisun HS500utv (2010) Oil Leak
If i could not find the part number or part on a diagram.
I'd get a caliper, get a thickness of remaining washer, diameter of shaft that goes thru it, max outside diameter.
And look for a generic round seal from avxseals.com and look for a seal with those measurements.
I have nothing to do with website. But i have ordered from them. Better seals than my oem cfmoto seals. And fast arrival time.
Or some thick rubber gasket material and make one.
Or maybe look for a different model or year parts diagram to see if something could match up.
Best of luck.
    • By Cory J
    • By Ductking1
    • By hisun junk
    • By Justine
    • By A P
