i put the factory kawasaki enclosure on ours.....while it doesn't seal up completely, it is good enough to allow me to heat the cab..............factory windshield is a hard Plexiglas................plowed snow for about 7 hours yesterday in 20 degree weather, and actually had to turn the heater down as it got too warm................
It's probably good that you decided to send it back. Those zipper doors look to me, like they'd have a never ending potential for trouble.
Not to mention that it'd be a pain, always having to take the time to zip open, then zip closed.
Do they not make one with door frames?
Yeah, the factory Kawasaki enclosure that Scott has comes with doors. You pay dearly for those doors though. I think all said and done, it runs about $1800. That's a lot for something I might use 6 weeks a year but looks like I dont have much choice. Part of our acreage is wide open farm land and the wind chill is beyond brutal there. Just came back from a bone-chilling ride that was far from fun but had to take the dogs on a poop run. Wind chill temps are about 15-18 degrees right now. The cab definitely helps a lot, as it blocks the wind. Heres a pic of the OEM cab. Looks tight. Doesn't look ratty or sag like most of the aftermarket ones. And it shouldn't for more than 50 percent more money.
I had a jeep with a soft top, only used it a couple months a year. So I know what you mean. You definitely want doors with a door hinge, instead of a flap. Then there's a proper door latch of some sort.
The expensive one will fit better too! Less icy breezes blowing up from somewhere. To me, it would be worth the extra money, rather than the aggravation of making due with sub standard items, when they are that important. Having a proper enclosure, up there in the Great White North, would be high on my priority list.
I agree that it's definitely expensive, but I'd still do it. It would be unpleasant for sure, but it would be buy once cry once. I'm hoping that you'll find an acceptable middle of the road option.
Well, if it would end up looking like yours I would probably leave it on close to all year as well. I have an SX XC and I'm not sure it would fit as tight on mine as yours. The only pic I've seen  of the OEM cab on an SX is a stock photo and it's hard to gauge the overall look. Is it hard to get on and off? I would imagine it would take some time. Here is the only image I've seen of the  OEM Kawasaki cab on an SX. It's not an XC but it's essentially the same specs with 24 inch tires. Mine has 26 inch tires.
lets put it this way, when i got the cab enclosure, i read the instructions and took it in to a dealer buddy to have it installed..............i did remove a door to have the window "fixed" last summer, and reinstalling wasn't bad.........but in the summer, if you unzip the windows, and run a fan inside, the temps are not bad.....but if you are using it for playing in the woods, i would recommend taking the entire enclosure off.....tree branches would reek havoc on the top..............
I really like the cabs that are  made by Essex manufacturing. They're not pretty, but it's all modular steel panels, and real  glass, for the windows. Essex makes good quality, heavy duty stuff, mostly for the military.
Expand
Might have a hard time getting them now, the owner  passed away several years ago, his wife and son decided not to continue the business..
  On 2/10/2022 at 12:15 PM, Scott Meszaros said:
i don't believe so........never tried, not sure why you would want it that way............
Expand
I was just thinking for warmer spring and fall days. My wife likes no top on warmer days (not that kind of top!) and I wouldn't mind having doors on all year round.  Doesn't seem like it's made for that easy on, easy off changeability though.
  On 2/10/2022 at 10:10 PM, kenfain said:
The website still shows a full catalog of kits available.
Expand
Yes, the website is still up, but the business is no longer in operation. I inquired about running boards for the 550, via email and phone, never got an email response and i get nothing when calling the phone number, finally i ran across someone on a hunting forum from Dallas who knew the owner, and said he had passed and the business is no longer operating.  Essex Manufacturing - Texas Hunting Forum
Finally found a pic of the OEM Kawasaki cab enclosure on an SX XC. Looks tight and I think the price tag is warranted so this is what I'll be getting for next winter.
Expand
as noted earlier, can't remove top and leave doors............is your wife one of those folks that drives around in a convertible with the windows up..........hahahahahaha
Lol. The door idea was for me. She likes it completely open, no top, windshield or anything when its warm enough.  i'm not a fan of the cab being open all the time but I understand the OEM enclosure isn't set up for having just the doors on. That's cool though, I look the look of it  and I'll leave it on  December to March.
  • 2 years later...
  On 2/2/2022 at 6:03 PM, rsar said:
20220201_162350.jpg  www.starknightmt.com/collections/soft-cab-enclosures
Expand
I have a 2013 4010 TransMule. I would like to come up with a soft cab enclosure to only enclose the front seat. I have a windshield and a metal top. I don't want to spend a fortune on one either. I will only use it during the winter hunting season and take it off. Will a regular 4010 cab enclosure fit the transmule??Any suggestions?
  • 2 months later...
Sorry, just saw this. Haven't logged in for a while. I'm not too familiar with the transmule but I decided against the stock enclosure after I saw the price. It was like 1,800 a couple years ago so probably even more now. Plus it needs to be professionally installed from what I read. That would likely mean another $500 to $1,000 dollars. I opted for the $600 stock windshield and hard roof instead. Also added a winch and bedliner. All for about $1500 less than the stock cab enclosure. I'll  just dress really warm!
    • By rdborra
    • By Flanman55
      2007 Hisun HS700  will not crank.  Replace the ignition switch. Same thing.  Replaced solenoid by the battery same thing. Can jump it and it starts good across the solenoid posts. Ran a jumper wire from switch to solenoid. Nothing
      can anyone suggest something else.
    • By bms stallion owner
    • By Croppy38
      I own a 2017 Challenger 750 and had the key way snap at the flywheel. It was removed and cleaned up and then the  flywheel was put back on with a new keyway. It snapped a second time so the flywheel and keyway both were replaced. They both seem to fit nice and tight. Put it all back together and it snapped again. I have no idea why it is doing this.
