We just added the ability to insert videos, by inserting URLs from Google, Youtube, Brightcove, MySpace, vSocial, & ifilm.
To insert a video, simply click on the video insert button rte-image-button.png and enter the URL of the video.
* We do not allow violent, sexual, or obscene material. If we receive negative feedback about a video posted, we reserve the right to remove it.
Thanks admin for the recent upgrades and the new video insert button. UTV Boards is looking very sharp now and easy to browse through.
Would it be possible to add a Joyner Renegade to the UTV Specific Forums and maybe even a Joyner Commando too?
Cheers Mike.
Cheers Mike.
Just added.
    • By camojay
    • By Xov
      I added lights to the Coleman Outfitter 550 last fall.   I bought lights on line from Nilight, a 300 W  12" light bar mounted forward and 2 square 4" floods for the rear.  Those are mounted on the roof corners facing rear and downward just beyond the tailgate.  Nilights seem to be of high quality, as I've had them on my garden tractor for 5 years and still flood the way ahead with great light.
      Both the front and rear lights provide amazing illumination making the OEM headlamps look like parking lights.  Made a connector for the front bar that plugs into existing headlamp switch so it is just part of that circuit controlled by the headlamp switch.   Rear work lamps were wired in using a rocker switch installed in the dash.  Backed up to the garden with the work lights and was able to harvest some tomatoes well past sunset.
      What have you used if anything for auxiliary lighting on your UTV?
    • By diamondjfarm
      Thanks.
