      Picked up an essentially new 2022 UT400 with 9 miles on it.  Decided to change the oil because it's probably never been done.  Pulled the dipstick and noticed it was overfull then went and pulled the drain plug and took off the filter and it was like brown water running out.  What should I start checking?
    • By Reynolds Rocket
      I have a 2017 Intimidator XD4 800cc 4x4.  It will run great and then it's like it goes into safe mode and only runs on 1 cylinder.  It's not fouling out the plug when it happens.  Some times when I stop and restart it, it works fine.  First I thought it was a spark issue, then a fuel issue, but I feel like it's a short in the wiring some place.
    • By Ronald
      Check engine light comes on after engine runs continuously for 5 minutes or so.  I can shut down the engine and restart and check engine light goes out, then comes back on after running 5 minutes or so?  What ya think?
    • By Rufus Fruge
      Who ever designed the placement of the oil dipstick on the T-Boss 550 should receive an award. He couldn’t have placed it in a more inconvenient location. Has anyone figured out an easy way to check your oil in these machines? Guess this is the place you refill also!
    • By Blaine
      Was wondering if anyone knows how to check a waterpump on a 2013 arctic cat prowler 1000 XTZ My cat overheated  and I was not working it that hard Have checked for antifreeze in oil in case it was a head gasket but its clean
      Next step will be to check pump and thermostat I know how to check thermostat  but clueless on checking pump I did refill rad and the started machine with cap off and coolant level did not change
