    • By Reynolds Rocket
    • By Ronald
      Check engine light comes on after engine runs continuously for 5 minutes or so.  I can shut down the engine and restart and check engine light goes out, then comes back on after running 5 minutes or so?  What ya think?
    • By Rufus Fruge
      Who ever designed the placement of the oil dipstick on the T-Boss 550 should receive an award. He couldn’t have placed it in a more inconvenient location. Has anyone figured out an easy way to check your oil in these machines? Guess this is the place you refill also!
    • By Blaine
      Was wondering if anyone knows how to check a waterpump on a 2013 arctic cat prowler 1000 XTZ My cat overheated  and I was not working it that hard Have checked for antifreeze in oil in case it was a head gasket but its clean
      Next step will be to check pump and thermostat I know how to check thermostat  but clueless on checking pump I did refill rad and the started machine with cap off and coolant level did not change
    • By chase ledbetter
      https://www.facebook.com/marketplace/item/278019541594965/?mibextid=dXMIcH
