7 hours ago, Joe Breaux said:
I just got ad  from our local Powersport Dealer..   NEW 2022  HONDA PIONEER 520  SXS ... $9599  in red and moss .... I wish they had those when I wasted my money on Massimo .  They show 42 UTVs and 71 ATVs in stock
Sometimes you get the bear, and sometimes the bear gets you 😎
Where is the dealership?  I might be interested in one,  thank you
Down here in swamp country dude ... Louisiana ..   Guys I have spent two days now on one of my Corvettes.. I know its not a 4WD, but I just thought I would mention it.. The thing has front engine but rear Trans and Differential, connected by a 6 inch Alum. Torque Tube that the driveshaft spins inside of.. No U-joints, 3  pressed in bearings .. To get it out,  the floor, the entire dual exhaust, the trans  and diff and the entire rear suspension had to come out.. What a Biatch.. Got it out, waiting on parts. Some engineer at GM is LAUGHING his ars off at me. Geeesh!  Somebody wanna buy me a beer??
    • By Chile
      2018 Massimo MSU 700 EFI. I realize that this engine is essential the same as in all of the HISUN based Yamaha clones out there. I am in the process of performing a top end diagnosis/rebuild. I have an AMAZON top end rebuild kit on order in anticipation of this activity.
      Question 1:  When exploring the myriad of top end rebuild kits on the market for these units there are some cylinder assemblies that have "686 cm3" badging next to the cam cain tensioner boss. Others compatible with the unit do not have this badging. The existing cylinder assy does not have the 686 badging. I am assuming that this simply verifies that the cylinder assy is for a 686 cm3 engine which of course the stock 700 series HISUN engines are. Am I missing something here or is this just a manufacturer artifact? With or without the badging the application listings all indicate compatibility with the MSU 700 series engines.
      Question 2:  I have reviewed at minimum a dozen videos associated with this rebuild. To date I have not found one that deals with piston/cylinder clearance and/or ring gap verification. The advertised specifications for these various "top end rebuild kits" all indicate: Cylnider bore = 102mm and piston diameter=101.5mm. The math yields a .5mm (as in 1/2 mm) difference. That seems to be a very large piston/cylinder clearance.  I realize I am referencing advertised specs rather than emperically measured values but the numbers have gotten my attention.  I have referenced the FSM and found it to be somewhat confusing in this regard. Hopefully the experts on this forum can enlighten me as to where my observations are faulty here.
      Any and all assistance is greatly appreciated .
      Thank you all in advance,
      Chile
    • By Tim n Deb
    • By barticus73
      I am looking to buy a small UTV to do work around my property and priced a brand new Massimo T-Boss 560 through Lowes @ $10,500 out the door or a  Dealer provided CFMOTO Uforce 600 at $11,500 out the door.    Are there any glaring reasons to go with the Uforce 600 at an extra $1000?  Is one model more reliable than the other?  Any input greatly appreciated.
      Thank you,
      Jerry
    • By barticus73
      I am looking to buy a small UTV to do work around my property and priced a brand new Massimo T-Boss 560 through Lowes @ $10,500 out the door or a Dealer sold CFMOTO Uforce 600 at $11,500 out the door.    Are there any glaring reasons to go with the Uforce 600 at an extra $1000?  Is one model more reliable than the other?  Any input greatly appreciated.
      Thank you,
      Jerry
    • By Sando
