  • Alex changed the title to Massimo msu 700 doesn’t want to rev up
Depends what you mean by "doesn't want to rev up". If it barely revs faster than idle, it's probably in limp mode which means the ECU is protecting the machine by preventing if from rev'ing because of some error.  Since the machine was tipped on its side, it's possible that there is air in the radiator hoses, which is fixed by burping it: raise the front wheels at least 20 inches off the ground and idle the machine with the rad cap off while adding coolant until all air bubbles are out.
    • By Brett
    • By rev6engines
      Black Friday is here, and we’re excited to give our offroad family 20% off on all parts and kits! Whether you're prepping for new trails or just fine-tuning your rig, we've got what you need to keep rolling. Now Is also a great time to upgrade your sled, winter's coming fast!
      If you have any questions or need help finding the right part, feel free to call, text, or email us. We’re here for you!
      Call or Text:
      801) 489-8697
      Email at:
      [email protected]
      Happy riding!!! 🤘
    • By Will Sutton
      I've got a 2023 UT400 (bought from tractor supply) and I've been beating my head against a wall with it.
      It will start and idle perfectly. The second I touch the throttle it sputters and dies.
      I've checked that the fuel pump is working  (it is).
      I've replaced the injector, throttle position sensor, O2 sensor, and intake air sensor. All with no change.
      I've just taken a look a the schematic, and there is a crank position sensor as well.
      Could this be the source of my troubles? If so, where is this thing located? I can't seem to find it on any drawings from the parts suppliers.
    • By shawn b
    • By TPlummer
