Massimo Buck 450 2022 Winch Remote Control
By camojay
By Rick A
By felo72
Hello all. I purchased a brand new Massimo Buck 250 EFI in June for our farm and I've had the parking brake fail on me twice. I have approximately 250 miles on the vehicle. The first time was less than a month after receiving the UTV. We all of a sudden lost brake pressure and it would not start. I tracked the issue back to the parking brake. Upon removing the chain cover, I noticed the brake pad was missing and the caliper piston was touching the rotor. I found a set of brake pads online and replaced them myself. It's worked for several months and just happened again. Seems like a design flaw. I'm reaching out to see if there's an upgrade option available, or if I should replace the entire caliper with the brake pads? Thanks in advance for any advise.
I submitted a warranty claim, so I'll keep this updated with what Massimo replies.
When I replaced the brake pads the first time, back in July, my Son made a video on YouTube to show the unique caliper design. Here's a link if you wanted to check it out:
By 2scoops
I am in need of an IAC for my throttle body. I contacted JMC and they said I had to buy the whole throttle body for $209. I left a message at Joyner USA...they haven't called back. I found a Chinese company which have them for $17, but shipping is $32. With that I still have to hope it is the correct one which arrives.
Does anyone happen to have one laying around they would sell?
I understand a workaround would be to eliminate it and use the idle screw. I believe that would cause problems with cold start ups??? Elevation changes???
