Just bought a brand new Hisun HS 750 Crew. Dealership started it up and drove it on to my trailer. Got it home and it won't start. Battery clicks over but nothing else happens. Tried jumping battery but no luck there.  Dealership is closed through the weekend and not sure what else to try.
On 3/4/2022 at 12:08 PM, Joe Breaux said:
apply the brakes , then start
Double check battery cables and battery posts, clean both then tighten battery bolts. Check fuses with a multimeter. Also check fuse block for starter, if it clicks when turning key to start, there may be a short in it. Tap it with pliers or small hammer. If it still clicks try shorting across posts on fuse block with a screw driver. If all fails take it back to dealer when it reopens. Good Luck!
    • By KWinTX
    • By BigWave
      Bigwave
    • By Gerald Mohs
    • By Gary Odom
