Not sure on the relay (or if it has one) but I do know if the driver's seat belt is not fastened, it will be limited on how fast it can go.
    • By Howard Elmore
    • By JSwearer
    • By A P
    • By amiracle40995
    • By Ridge Runner
      thanks
      Ridgerunner
