I have been looking at the different pull-behind implements for UTV/ATVs and am looking for advice/reviews on which ones to purchase. I already have a 44" Swisher Trail Cutter and a 60" Massimo Snow Thrower. The Trail Cutter is great, just wish I had the 60" one and the snow thrower is OK; I have to drive really slow with it or it will bog down. I have 14 Acres of over grown pasture land that was originally used for cattle and then horses. Over the past 20 years it has been neglected and is overgrown with weeds and bushes. I have a local farmer that is willing to rejuvenate  about 10 acres and start planting simple crops like hay, corn or soy. The other 4 acres I want to pretty up with lawns and trees but the land is rough. I have been looking at compact tractors as well, but am getting sticker shock just looking. I am new to this so I am not sure what equipment to purchase. Any experience and/or ideas out there?
Rent a skid steer with a mulcher attachment.  Looks like an oversized stump grinder.  We used them to clear out under power lines, which wasn't  done that often so trees would get to 6-8" in diameter and that thing would eat them up.  When you're done clearing just run it over the cleared ground and it's tilled and ready to plant.
    • By Chile
      2018 Massimo MSU 700 EFI. I realize that this engine is essential the same as in all of the HISUN based Yamaha clones out there. I am in the process of performing a top end diagnosis/rebuild. I have an AMAZON top end rebuild kit on order in anticipation of this activity.
      Question 1:  When exploring the myriad of top end rebuild kits on the market for these units there are some cylinder assemblies that have "686 cm3" badging next to the cam cain tensioner boss. Others compatible with the unit do not have this badging. The existing cylinder assy does not have the 686 badging. I am assuming that this simply verifies that the cylinder assy is for a 686 cm3 engine which of course the stock 700 series HISUN engines are. Am I missing something here or is this just a manufacturer artifact? With or without the badging the application listings all indicate compatibility with the MSU 700 series engines.
      Question 2:  I have reviewed at minimum a dozen videos associated with this rebuild. To date I have not found one that deals with piston/cylinder clearance and/or ring gap verification. The advertised specifications for these various "top end rebuild kits" all indicate: Cylnider bore = 102mm and piston diameter=101.5mm. The math yields a .5mm (as in 1/2 mm) difference. That seems to be a very large piston/cylinder clearance.  I realize I am referencing advertised specs rather than emperically measured values but the numbers have gotten my attention.  I have referenced the FSM and found it to be somewhat confusing in this regard. Hopefully the experts on this forum can enlighten me as to where my observations are faulty here.
      Any and all assistance is greatly appreciated .
      Thank you all in advance,
      Chile
    • By Tim n Deb
    • By barticus73
      I am looking to buy a small UTV to do work around my property and priced a brand new Massimo T-Boss 560 through Lowes @ $10,500 out the door or a  Dealer provided CFMOTO Uforce 600 at $11,500 out the door.    Are there any glaring reasons to go with the Uforce 600 at an extra $1000?  Is one model more reliable than the other?  Any input greatly appreciated.
      Thank you,
      Jerry
    • By barticus73
      I am looking to buy a small UTV to do work around my property and priced a brand new Massimo T-Boss 560 through Lowes @ $10,500 out the door or a Dealer sold CFMOTO Uforce 600 at $11,500 out the door.    Are there any glaring reasons to go with the Uforce 600 at an extra $1000?  Is one model more reliable than the other?  Any input greatly appreciated.
      Thank you,
      Jerry
