Posted (edited)
Can anyone give me an idea what they think this sound could be, I just put new clutch on started it up and heard this sound. Sounds worse when you listen by the air intake.  Any help would be appreciated!
Edited by Easyrider
Video isn’t showing to hear the problem keeps giving me an error
I might know what causes your noise. I got a very similar sound when I removed and re-installed the primary clutch on my 2018 Odes Dominator 1000 (a HISUN relative). There's a plastic washer or spacer that rattles if the clutch bolt isn't torqued enough. Check your HISUN manual for the correct torque. I think mine needs to be torqued to 70 or 75  lbs but I didn't torque it quite enough so it still makes this racket. I might just remove this washer next time I have to remove the clutch because I'm afraid of stripping the bolt if I tighten it more..
    • By Marie
    • By Grant
