2022 Can Am Maverick X RC 1000R Windshield
By HighSon
This mod is not for the fainthearted, as it requires some basic metal fabrication and welding skills. But the result is worth the effort IMO. I chose an aftermarket Honda Talon windshield based on economy, size, and construction (aluminum frame, DOT glass, folding, windshield). It fits OK, a little narrow at the top, and you need to incorporate the lower section of the original acrylic windshield and build some additional plates, but better than being too wide. If you are wondering why I attacked this mod, it's because mine is driven daily on the street. Tired of fading, scratchy, hazy plastic. Sucks in the rain; sucks at night. Now I can see.
By didgeridoo
By Unhappy Kioti K9 Owner
I own a K9 with 50hrs that has been in for repair more than once the farm. Multitude of issues, trying to file lemon on it but interested in knowing if owners are organizing for a class action suit. The dealer informs me there are “a lot of owners very unhappy with these”.
By Xov
By FTG-05
