Hi new here. Just bought a Massimo Buck250X for some neighborhood riding. New unit rides great and seems to work fine, except when full throttle for 5 min or more the check engine light comes on. Air filter is fine, and oil is topped off, any ideas?
I figure it’s just a sensor issue but I’ve been wrong before.
  • Alex changed the title to Massimo Buck 250 check engine light
1 hour ago, TapBoss said:
Is this new or used?  If new,  probably shouldn't be at full throttle until the thru break-in period.
Thanks. It’s brand new. Dealer only told me to change the oil at 50 miles. What was your rpm limit for the break in period?
    • By ToughLuck
      Greetings All,
    • By Joe Breaux
    • By aefron88
