New to the forum looking for information from the experts.  Brother bought a Massimo hs700 from a friend, needed a new rear axle.  Got it home drove it around a little (since it still had 3 axles)and noticed the speedometer reads zero.  Replaced the axle and put a new spd sensor in it and still doesn't work.  Bench Tested the old sensor and it worked.  Unplugged and Checked the wiring from instrument cluster with key on  and I get 6.8v from signal and 7.2v from the power supply.  Isn't it supposed to be 12v power supply zero volts signal.  Has analog speedometer.
I'm just kinda assuming the instrument cluster is bad, just wondering if anyone can confirm on theirs, im pretty sure blue signal should have 0v from instrument cluster.  I know its a cheap rhino clone but rhinos used  a different speed sensor and location. So I can't look anything up on that
    • By SouthernGypsy
    • By Poppateets
    • By tskm
      Tom
    • By Xov
