I just got a what I believe is a HiSun UTV.  The faded stickers on the hood show HS600UTV.  I have pulled the cover off of the engine in and most of the vacuum hoses are rotted and not connected to anything anymore.  I am having issues finding a vacuum routing diagram anywhere to determine how these should be connected so I can replace the hoses.  I was able to get it started the other day but had fuel spraying out of the carb.  Can anyone help with where these hoses should be running.  I do not know what year this thing is and as I said I'm assuming the model number makes it a HiSun.
    • By Dennis
    • By CapnWalleye
    • By Marie
