I'll be the first one to give you guys some feedback. I like to colors and the fact that it is light in here for the forum controls. Easy to navigate and loads fast. You will obviously just need some members. I'm sure they will come eventually. Simple to use, looking forward to the community. Good luck.
  • 1 year later...
I just joined and as I had a UTV that didn't have it's own section, I made a request and it was granted. Thanks (or as we say where I'm from, on yar mate)utv board, that shows us all you are pro-active.
Cheers Mike :):):)
Thank you all for the feedback! We will adjust this place as needed by the requets and feedback of our members. Spread the word, and welcome aboard to all of you that are new! I'm excited to see the participation!
    • By Jacob E freeman
    • By Kingfish
    • By Ridge Runner
      thanks
      Ridgerunner
