2021 RK 750 shifter adjustment
By mcraigchr
Howdy y'all,
Craig C.
By camojay
1400 miles on it
20240817_133539_1.mp4
By Rick A
By Jim Kessell
2005 American Landmaster
EH65 Subaru Robins
By Buck
My father-in-laws 750 hisun will not change gears unless he completely turns the motor off then shifts. I thought it might be a brake problem but he thought clutch. He took it to a jackleg down the road and he basically charged him $300 and did not fix a thing. Any ideas would be useful because he really can’t afford throwing money at it.
