I have a 2017 massimo 500 it ran good but wouldn't charge I checked the stator and it was burned up so I replaced the stator and rectifier and now it just cranks it won't hit a lick but it started fine until I replaced parts
Its a tough one for sure. I wouldn't think the stator and rectifier would of had anything to do with it starting as long as it cranks.  I guess I would do what Michael says first and check the fuses..
On 4/13/2022 at 7:08 PM, Mike6969 said:
Did I do something wrong
You might have missed a wire connection or something similar. It's not that uncommon to break other stuff while you're working on something. It happens, and you shouldn't worry about it. Just move on, and focus on finding the problem.
You need to go over all the wiring that might have been disturbed, or disconnected, while fixing the last issue.
It cranks, but have you looked to see if it's got spark? If not, then check the coil
Please outline all the trouble shooting you have done so far. Things like, does the spark plug spark. Does the coil get 12 volts? and so on. Stuff like that would be a big help in getting help.
    • By Mike Jenkins
    • By Sando
