    • By rev6engines
      Black Friday is here, and we’re excited to give our offroad family 20% off on all parts and kits! Whether you're prepping for new trails or just fine-tuning your rig, we've got what you need to keep rolling. Now Is also a great time to upgrade your sled, winter's coming fast!
      If you have any questions or need help finding the right part, feel free to call, text, or email us. We’re here for you!
      Call or Text:
      801) 489-8697
      Email at:
      [email protected]
      Happy riding!!! 🤘
    • By Kingfish
    • By Woody77
      UTV MASSIMOREPLACED STATOR WANT start replaced rectifier still want start stator ohms out 5 ohms each leg what could be wrong at this point
