2015 MSU 500 - Oil problem has me stumped
By CaptainMorgan
I have a Bobcat 2200 Diesel (built by Club Car) with a 2-weight Team Primary Clutch I want to rebuild, possibly replace. The clutch has an annoying rattling sound at idle and appears the rollers and weights are worn and loose. When I opened it up, everything looks clean and in great shape. It's just that all the moving rollers and weights seem to have way too much play in them, possibly causing the noise. I've searched for clearance and torque specifications with no luck at all. The UTV has less than 500 hours on it. Any ideas?
By Chile
Chile
By Kevin Ullman
By SkyPilot56
