Water in oil, feel blowback pressure off intake valve  area. Thanks for responding . I think there is a seal behind the oil gear that  is causing the water  leak.
    • By Graffy
      Is there a diagram of all of the grease zerks for a Coleman UT 400?  Mine squeaks like crazy and want to try and remedy it.
    • By boydog40
      thanks guys
    • By SouthernGypsy
