heh...I was going over the buggy last night and noticed my fan belt had jumped a rib and wore a hole in the plastic timing belt cover....Anyone have an idea how much of a pain this is gunna be to replace ????
Guest Lenny
You may be able to use epoxie glue to fix it. If you get the right stuff, it will hold. E-mail 3m corporation and tell them what your doing and they can tell you exactely what to use. About 3 years ago I bought a brand new $300 pond pump for $28 on ebay because nobody wanted it because of a a cracked plastic housing. I used epoxie and It's been working ever since. Of coase if it's cheap and easy to replace, do that.
    • By Cory J
    • By Jacob E freeman
    • By Kingfish
    • By Fishing Wiskers
      Top speed is 30mph on flat grass ground.  but it will not go up minor hills forward or reverse without a runing start.  If you start at the bottom of the hill machine will stop about 1/2 way up.  I have the engine cover off and you can see the outside of the drive clutch will stop spining., and the engine does bogg down some.  Dosent matter if engine is cold or warmed up.  Seat belts are connected.  Fuel is clean
      I am not sure how to check for codes with this machine,  can anyone teall me how to do it?
      Compression with hot eng is 145,  valves adjusted to .005 with a cold engine.  Dash shows 426 hours
    • By Browner010
