it looks like the rubber gasket that is used to weather proof the main instruments ( signal light, speedometer , tachometer, etc) on my Coleman 400 UTV that I purchased in the fall of 2021 is falling down across the instruments. This is obsuring all of the indications at the top and is now affecting the operation of the tachometer since it forms the circle around the tach.  Anyone else had this problem? is this something that I can take apart and fix or is this something that is sealed?
That sounds like it should be a warranty Issue. If that's not working out, then you'll need to look to see if you can access the back of the dashboard.
From there, you should be able to see how to remove the speedometer cluster assembly.
Even if the assembly is permanently sealed shut, it can still be opened, if you're careful.
  • 10 months later...
I have the same problem -- I thought it was rubber also...  Took it apart, the piece is rigid plastic -- it looks as though it has been subject to heat and melted.  I'm in the process of trying to get Coleman to send me the piece...  We'll see.
    • By Howard Elmore
    • By Will Sutton
    • By Greg Kilgore
      Plumbing parts list.
      2 1" x 3/4" x 1" PEX Tee
      1 3/4" PEX ball valve
      1 1" PEX ball valve
      Wide view of the plumbing.
      Kilgore.
    • By dman66
