Kymco Uxv lift kit?
akman
  • 1 year later...
    • By Browner010
    • By Duncan
      I got a utv from lowes it has one tire in the back that is the same size as the front tires so it has 3, 26-9-14 and 1 26-11-24. i want to change the rear tire to the same one as the other.So instead of buying a new rim will a 26-11-24 tire fit on a 26-9-14 rim.
    • By hdtran
    • By mac66
    • By sxr951
