I have a 2020 PRO FXT LE that we primarily drive on the blacktop roads of our community and currently the unit has 2,400 miles on it. We use it like a golf cart. The factory tires in the front have worn pretty bad due to riding it in the street so my plan is to change them  out to a DOT street tire. Do I have to change all 4 tires or can I just replace the fronts and keep the factory tires in the back? The rear tires are in great shape but didn’t know if I would notice a difference in ride having two factory tires in the back and two street tires in the front.
Thank you.
  • Alex changed the title to 2020 Kawasaki Mule PRO FXT LE DOT tires
I don't think the ride would be any different, however you can probably expect the rears to wear out soon as  most stock tires aren't made for asphalt/hard surfaces, as you've seen on the fronts.
    • By Some random dude
      2015 Hisun 700 Utv
    • By Unhappy Kioti K9 Owner
      Greetings All,
    • By Xov
