2021 Hisun Vector 700 accessory switch
By Jr Perez
By Kingfish
I have done a LiPo4 battery upgrade on my E1. I have reprogrammed the charge profile to #386. With the onboard BMS the controller cuts off all charge from the IC1200 when the battery reaches 100% to prevent overcharge. When this happens the charger begins flashing the yellow light and displays the error code 013 which is telling me the battery is no longer accepting a charge input which is as it should be. I hear a relay switching in and out every few seconds as the charger continues to try to reach the shutoff charge profile voltage. My question is will it cause any harm to the IC1200 to stay in this state for hours or maybe even days if I don't get out to unplug it? I used to leave the E1 plugged in all the time with the old Discover batteries.
By Texjpr
By Paul in Wisconsin
I have a 2023 Tracker 800SX LE that I want to add a sway bar to.
The service manual shows how to remove and reinstall the sway bar.
I called Cabela's to try and get the saw bar. They said they can't get one and the 800SX doesn't have one!!?? Then why is it listed in the service manual?? No answer from them.
Have any of you found a saw bar that fits and what did it cost?
By hetovi
Hello everyone.
