Have a 2022 UF 600 and wondering how the air filter is removed; I've loosened a hose clamp to the left of the filter, and the filter doesn't pull away easily...
Are there any videos on the procedure?   Or any input?   The dealer tells me to "clean" the air filter after every 3rd use and is unable to show me how to remove the filter...
  • Alex changed the title to 2022 CFMOTO UForce 600 air filter removal
  • 5 months later...
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By A P
    • By PossumTruck
      Greetings,
    • By Gary Gallo
