Afternoon,
New owner of a 750 traded my Harley for it from my Son... It has 16hrs on it and has just been sitting covered in a garage since purchased. I am trying to find a Shop/Service Manual and want to get a good one and not learn the hard way. I would like to have a Hard Copy as well as CD back Up... Can anyone recommend one that they have purchased? I did see a post here for a PDF download but it was an older post and said unavailable.
Also welcome to hearing your thoughts of what you would do if you just took delivery of this.
Thx
Keith
    • By Frank in MI
      Thanks for accepting me!
    • By hisun junk
    • By Poppateets
    • By Jacob E freeman
