I can't figure out what's wrong with the shifter in this utv. When running at 1300 rpm it takes brute force to shift in and out of gear. When I shit off the engine it shifts like butter. Is there something I'm missing here?. I thought maybe it was to high an idle but from what I gather 1300 to 1500 is where it should be. Thanks for any help
There’s a mechanical shift interlock that requires depressing brake pedal to shift gears. I’m currently fighting mine. Interlock would become stuck , requiring spray lubricant. Recently removed interlock but shifter  is super loose and I’m afraid a rough ride would cause it to slip out of gear. Reinstalled and lubricated the interlock cable, also changed shift cable, kind of a pain to adjust cable but done. Yet to make an extended ride to report results.
    • By klm
    • By Edelbrock
      Thoughts?
    • By Duane Baker
    • By UTVLover253
      What you love about it
      What frustrates you
      – Adam
