    • By Sisco
      Does any have a part number for the fuel pump sock for a 2016 challenger 700 efi. Does not show on any parts diagram but the old pump has one on it.
    • By Mnfish
      I have a 2016 Cub Cadet 750 Challenger Crew. My in tank fuel pump is inoperative. Can I put in an external inline electric fuel pump to replace the intank one? The inline ones are about $350. An inline electric one is about $25. Both are easy to replace just really expensive for the intank one. Any kind of inline external pump I should look at? What PSI is needed? Thanks for any help
    • By johnpeter
      2016 Polaris Ranger 570 4WD On Ebay
      https://www.ebay.com/itm/166657642388?
    • By Felderlostnspace
      2016, Hisun 500 turns over great but Spark plug is firing when I turn the ignition key on. I’ve got good fuel pressure to the injector. Pulled plug out and it is wet with. gasoline. Air filter is clean. Turns over great just does not even try to pop or start.. I’ve checked off uses and they are good when I turn the key on I’m getting power to the injector.. I’m not hearing the injector pulsing, but may just be my hearing.. With the spark plug getting wet with gas I feel like the injector is pulsing and spraying. Any suggestions would be great. I don’t know the hours on the unit offhand, but it has 600 miles on it. Thank you for your comments and advanced.
