Massimo MSU 500 wont go in any gear
By Greg Kilgore
Got a 2021 Axis 500.
Manual states 38nm.
Anybody got the answer?
By D MAYNARD
By mac66
The good...
-Fairly comfortable to drive.
The not so good...
Overall Impression...
