On 10/24/2024 at 9:15 AM, Jarheadtx said:
Great information. I did this install last night and it worked perfectly. Only thing I did different was to make my own battery cables to get the batteries configured in the best balanced configuration based upon the balanced PDF doc you provided.
Is it better to use LiTime 4-pack 48V 30Ah GC2 rather than 2 48V 100ah ?
On 7/15/2024 at 5:36 AM, GNFO said:
That looks pretty good as long as you can make it fit.  Two of them would give you a lot of range.  Just make sure you get bigger cables to parallel them so they can handle to current.
I doubt the regen is capable of 400A. That's the max the motor can take as an input, so regen is going to be no more than ~60% of that max due to different losses in the system.  Probably even less than that, and I would guess the motor controller would limit the regen anyway because the old Discover batteries wouldn't have been able to handle it.
    • By dman66
    • By camojay
      1400 miles on it
      20240817_133539_1.mp4
    • By GunnersTacklebox
