Posted (edited)
Just bought a 2022 Coleman Outfitter 400 cc UTV.  When I put it in geqr and slowly give it gas it bumps into gerar with a loud clunk and a jerk.  When the vehicle is under stress while revving up or going up hill, it jumps out of gear a lot..Gotta be bad for the tranny..Anyone else having this issue??
Nathan
Edited by Nathan51
added more info
  • Nathan51 changed the title to 2022 Coleman 400cc Outfitter bumps into F nd R gear very hard and jumps out of F gear.
    • By Ductking1
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By Howard Elmore
    • By Justine
