2020 American Landmaster L3 Very Noisy
By Roadstar515
Regards, Rick
By Alien10
I use my Hisun 550 (with the Coleman stickers), for general work around my 10 acres of hilly land. Hauling firewood, some dirt and mulch, and debris clean up. Also felling dead standing trees in the woods and hauling rounds out to the barn for splitting/stacking.
Here's my question: Those who use their UTVs with towed drag implements or snow plows, have you noticed any issues with early clutch slippage or failures? Or premature belt wear? Other drive line issues??
Thanks in advance for any experienced thoughts and comments.
By Jacob E freeman
By Josh5696
So I've got a 2022 Axis 500 UTV with only 50 miles on the odometer. It seems to have a strange grinding/squeeling noise coming from the clutch when decelerating or going down hill at lower speeds. Did some research, and found out this is apparently a fairly common thing. Alot of sources suggest the one way bearing is responsible. I'm hearing about quite a few horror stories about these bearings going bad on practically new machines, and when they replace the bearing it goes bad again shortly after.
Has anyone come up with a solid fix for this? I've read it may be possible to run the UTV without the bearing at all, is that true? Are the $20 replacement bearings from eBay and Amazon complete garbage, and is there a better one way bearing out there that's built stronger? Is there something else causing this bearing to wear out faster, or is the stock bearing complete junk?
Any input is appreciated, thanks in advance!
