New Trophy Trooper Just Finished
By Robbie Wyre
By mark walkom
By shawn b
By Isaac
I have a 2013 odes dominator when I get in it. It ideals fine but when you give it gas it bogs and goes and bogs and won’t go passed 30 can anyone help me
