Hi.
In a matter of only two month's I had two broken cages in the CV axle. First the one from the rear left axle, right now is the one on the rear right axle that is making noise, possibly cracked and will be breaking completly soon.
I can only find online complete axles from hisun.
The last one I bought it from aliexpress, from this link:
https://pt.aliexpress.com/item/1005003966116204.html?spm=a2g0o.store_pc_allProduct.8148356.11.2c3d4cc0OusFyL&pdp_npi=2%40dis!EUR!€ 76%2C84!€ 76%2C84!!!!!%400b0a556616545900491728973e44fd!12000027589649597!sh
Reference was:
  • Parts No.:47250-115-0000, 26110-055-0000
This cost me about 146€.
My question is:
Does this happen often to any of you?
Is there any way of getting only the CV joint instead of the complete axle?
Thank you!
Picture of the cage in attachments.
    • By Karlibob
    • By Blair
      Greetings All,
    • By Grant
