Need Rims
By didgeridoo
By mac66
By Alien10
A while back I was looking at an auction UTV plow and the mounting of it. Looked like it had an "H" bar with two pins that hooked into brackets on the front frame of the UTV. I have a bunch of 1/4" x2" angle iron, and some 2"x1/2" flat stock in the barn. I was thinking of welding up a bolt on implement mount that would provide 2 holes about 14" apart, that pins could be used to hook up an "H" frame for a plow or even a straight bar across with pins to hold it in place. The angle iron "A" would utilize the existing bumper mounting bolts front and bottom, and have the two channels "B" with holes for individual pins or one large bar across. Those channels would be welded to the ends of the angle iron.
Anyone ever try this for a front mount? It would be close to this one that is for sale on the net. It is supposed to fit a KFI plow mount.
By Mater Help
I have a 2019 Bennche Warrior that I mostly use around my property for odd jobs. I also cruise the neighborhood and make short runs to the local pub and neighbors houses. The exhaust system is super loud. I was hoping to find something that will fit and work that is quieter. I have included a photo of the system that is on the unit now. Any ideas or recommendations?
Second question: Recently, it has become hard to shift from park to any gear if the engine is running. The shifter moves fine if the engine is off. It is almost as if the clutch (no pedal) is not disengaging completely. I have not tried to do anything to correct the condition yet but as it gets increasingly more difficult, I need to do something. Looking for a place to start. Nothing in the service manual that I can find.
Any help will be greatly appreciated,
By sxr951
2015 massimo 700.. need cylinder bolt! it some special cut from factory,, its a 125 thread but its like between 8 and 10 mm dont know where to find any ideas? thx
