Need Rims
Paiute3
Guest Lenny
I need two stock front rims for the Trooper if anyone has any they would like to sell please let me know.
George
I have the stock wheels and tires off my Trooper I was going to put on Ebay. If your interested in the fronts, I'll let you have them with the tires for $150.00. Let me know, I could bring them to Logandale.
Hi Lenny,
I'll take them. Thank-you. Looking forward to seeing you in Logandale.
George
Just got back from a trip to Little Sahara sand dunes. I have front rims all around and General Grabber AT2 27x8.50 R14 tires on them. They performed great!!!!!! I also went on trails and roads and I was very happy with them. I was running 10 psi front, 11 psi rear. I had just backed the front shock springs off to where there is only about a 1/4" of thread left showing.
Out in the sand, I found that I could go just about anywhere with no trouble. These were a lot better than the stock tires, but they would probably out do me in the mud, but I hate mud. :P While out there, I talked to a tire dealer and his comment about my tires was they are as close to BF Goodrichs as they can be without them being sued, and BF Goodrich is the most popular tire for the race truck crowd.
Guest Lenny
How did the softer spring settig and tire pressure feel. You probably could go even lower on pressure in the dunes. I run 6 psi in front and 7 in back for sand, about 10 and 12 for trails, about 7 and 8 for rockcrawling.
It was great, I could drop over any hill out there and didn't have any regrets for it as I came to the bottom and the woops were no problem, I'm really very happy with the way it's handling now. The tires worked good in the sand and on roads.
    • By mac66
      A while back I was looking at an auction UTV plow and the mounting of it.  Looked like it had an "H" bar with two pins that hooked into brackets on the front frame of the UTV.   I have a bunch of 1/4" x2" angle iron, and some 2"x1/2" flat stock in the barn.   I was thinking of welding up a bolt on implement mount that would provide 2 holes about 14" apart, that pins could be used to hook up an "H" frame for a plow or even a straight bar across with pins to hold it in place.   The angle iron "A" would utilize the existing bumper mounting bolts front and bottom, and have the two channels "B" with holes for individual pins or one large bar across. Those channels would be welded to the ends of the angle iron.
      Anyone ever try this for a front mount?   It would be close to  this one that is for sale on the net.  It is supposed to fit a KFI plow mount.
    • By Mater Help
      I have a 2019 Bennche Warrior that I mostly use around my property for odd jobs. I also cruise the neighborhood and make short runs to the local pub and neighbors houses. The exhaust system is super loud. I was hoping to find something that will fit and work that is quieter. I have included a photo of the system that is on the unit now. Any ideas or recommendations?
      Second question: Recently, it has become hard to shift from park to any gear if the engine is running. The shifter moves fine if the engine is off. It is almost as if the clutch (no pedal) is not disengaging completely. I have not tried to do anything to correct the condition yet but as it gets increasingly more difficult, I need to do something.  Looking for a place to start. Nothing in the service manual that I can find.
      Any help will be greatly appreciated,
    • By sxr951
      2015 massimo 700.. need cylinder bolt!  it some special cut from factory,, its a 125 thread but its like between 8 and 10 mm  dont know where to find any ideas? thx
