A few days ago a saw a rubber piece on the floor of my Axis 500 but wasn’t sure where it came from. I later realized it was the rubber gasket around the hand brake. Apparently the squirrels which chewed up my shifter boot also pulled the hand brake gasket out, slightly damaged. However, when I went out the next day to try to install it, I found the filthy tree rats stole it!  I can’t find it listed on eBay or Amazon (the Hisun 500 will be the same). What are some good sources for getting parts like this?  Do I need to go to a UTV service/dealer?  I’ll make o e out of rubber before spending $50, if it comes to that.
  • 4 weeks later...
    • By KnS
      Hey Team, our issue is not as bad as some I've read here...  We put some songs one a 64GB USB stick, plugged it in and the USB icon is still greyed out and won't let you select.  Any suggestions?  All the songs are in the root directory.  Thanks, Kevin & Shelbie
    • By MikeM1
      2025 axis xs 750 no place to mount license plate and no light for it has anyone fixed this issue
