A few days ago a saw a rubber piece on the floor of my Axis 500 but wasn’t sure where it came from. I later realized it was the rubber gasket around the hand brake. Apparently the squirrels which chewed up my shifter boot also pulled the hand brake gasket out, slightly damaged. However, when I went out the next day to try to install it, I found the filthy tree rats stole it!  I can’t find it listed on eBay or Amazon (the Hisun 500 will be the same). What are some good sources for getting parts like this?  Do I need to go to a UTV service/dealer?  I’ll make o e out of rubber before spending $50, if it comes to that.
  • 4 weeks later...
    • By CapnWalleye
    • By CapnWalleye
    • By Bobbers
    • By D MAYNARD
                                    Thank You,
                                  D Maynard
