    • By Duncan
    • By Xov
    • By Pilot1996
      When researching the Tracker, I was interested in the 800SX LE. The original sales literature indicated that the LE came with 27x9x14 and 27x11x14 tires. When I went to pick up my Tracker, it had 26” tires on it. I called Tracker before paying for the Tracker and was told they had supply issues and could not get 27” tires. I’m curious to know if anyone has taken delivery of an LE with 27” tires in stalled? I just recently installed 27” tires and am happy with the added ground clearance and beefy look the machine has taken on!
    • By Havoc321
      I’m looking to have my 2022 800sx fit in the 10’ garage of my toy hauler. I thought about removing the dump bed, so I wondered how far the dump extends beyond the tires.  Thanks!
    • By riggy400
      Bought a Coleman 400 UTV (pretty much a Hisun), the previous owner tried to replace the timing chain, couldn't time it properly and sold it to me. After some hours I figured out how the timing all is supposed to be set (I think/hope) and as I am reassembling, I noticed that the water pump gear was awfully hard to spin. I held the gear with my hand and spun off the impeller. I checked the bearing, spins great no obvious issues noticed other than this o-ring which seems to be out of place? When I remove this o-ring and reassemble the WP, it seems to spin nice and easy without a drag. I looked up the service manual (although very inaccurate info there often) and don't see this o-ring present. Am I missing something here or what? Any input?
      This is not easy to access once the engine is back in the machine so would like to avoid having to deal with this if it becomes a problem.
