Removed from winter storage and starter not working. Replaced battery and starter relay. No good . Relay clicks when key is turned but no action at starter. Removed starter and it worked fine on bench. Is there a in-line switch or contact that could be bad?
I had a very similar problem with a 2018 Odes 1000. I had a loose ground on passenger side of engine (for Odes 1000). This might not be your problem but it's something to check.
I just purchased a 2013 800 Dominator and the ignition switch is finnicky...meaning sometimes the only way it will start is to only turn the key about 2/3 of a turn vs all the way to the stop. Its a different issue than yours as my starter will actually spin but it wont actually fire/start until I back it off slightly.
I have never owned one of these before so I am learning as I go.
    • By SkyPilot56
    • By Mike Jenkins
    • By Some random dude
      2015 Hisun 700 Utv
