I have a hisun 700 that was running and driving good but a while ago it just stopped moving. It was acting like it was in neutral but would shift through all the gears. I pulled the engine and put a new wet clutch in and then it was driving again. After about 20 minutes is stopped moving while I was driving. So I pulled off the outside clutches and moved the transmission shaft while in gear and it just would spin nothing happened. I decided to pull the engine again and something with the movement of me pulling the engine must have did something cause now spinning the shaft would spin the drive shaft. I split the engine apart to get at the transmission and I can’t find anything broke or anything there is some metal shavings but can’t find where they are from. Does anyone have any ideas?
    • By CapnWalleye
    • By Marie
    • By Marie
    • By aefron88
